Solved
Help choosing parts
I would like to build a computer for my senior project, and I'm looking to get a 2500k/3570k liquid cooled in a fractal designs Node 304 Mini Itx case. Can anyone recommend a good Mini Itx Mobo, GPU, Ram, Liquid cooler, Hdd, Ssd, and PSU for my budget of 925$
2 answers Last reply Best Answer
More about help choosing parts
  1. Best answer
    You might want to fill out this form.
    http://www.tomshardware.com/forum/353572-31-build-upgrade-advice
    Also if your doing it as a senior project, wouldn't you want to be documenting your learning process and showing your understanding of why you picked various components.
    Instead of going "this guy called Chalk or something said I should get this, so I did".
  2. Best answer selected by shawna593767.
Homebuilt Systems
