Solved
Help with this build.
This is the first computer I will be making on my own. I am trying to make the highest best gaming computer available. I am saving up the money and honestly don't care how much it costs. Please tell me if any of these parts are incompatible and suggest any upgrades or better choices. Thanks in advance for all your help.
COOLER MASTER HAF X RC-942-KKN1 Black Steel/ Plastic ATX Full Tower Computer Case
ASUS Rampage IV Extreme LGA 2011 Intel X79 SATA 6Gb/s USB 3.0 Extended ATX Intel Motherboard
Intel Core i7-3930K Sandy Bridge-E 3.2GHz (3.8GHz Turbo) LGA 2011 130W Six-Core Desktop Processor
COOLER MASTER Hyper 212 Plus RR-B10-212P-G1 "Heatpipe Direct Contact" Long Life Sleeve 120mm CPU Cooler
CORSAIR Vengeance 64GB (8 x 8GB) 240-Pin DDR3 SDRAM DDR3 1600 Desktop Memory Model
EVGA 04G-P4-3687-KR GeForce GTX 680 FTW+ w/Backplate 4GB 256-bit GDDR5 (Getting two for SLI over 1 G690)
Western Digital WD VelociRaptor WD1000DHTZ 1TB 10000 RPM SATA 6.0Gb/s 3.5" Internal Hard Drive -Bare Drive
SAMSUNG 840 Series MZ-7TD500KW 2.5" 500GB SATA III Internal Solid State Drive (SSD)
ASUS Black Blu-ray Drive SATA Model BC-12B1ST/BLK/B/AS
CORSAIR AX1200i 1200W Digital ATX12V v2.31 and EPS 2.92 SLI Ready CrossFire Ready 80 PLUS PLATINUM Certified Full Modular
SAMSUNG B550 Series S27B550V ToC 27" 2ms GTG HDMI Widescreen LED Backlight LED Monitor (Two screens)\
Thanks again for any help and suggestions.
4 answers Last reply Best Answer
More about help build
  1. Best answer
    I would choose a Better brand GTX 680 like http://www.newegg.com/Product/Product.aspx?Item=N82E16814127695
    And for SSD get a Samsung 840 Pro series. Its alot faster
  2. for the cooler go closed loop and not the hyper 212+ if you in insist on the hyper 212 at least get the EVO there are no gaps between the heat pipes and the aluminum base.
    http://www.newegg.com/Product/Product.aspx?Item=N82E16835181017
  3. Thanks for the responses i will definitely make those changes.
  4. Best answer selected by bywr13.
New Build Computer Systems Product
