Closed
Going to buy a GPU in 4 hours, need last minute help
Soooo I currently have a http://www.tms.co.il/product/11299 and it is REALLY loud, can't overclock it one bit because it gets VERY hot on stock clocks and voltage, using 70% fan and it rips my ears apart and still on 60+C while BF3'ing.
I changed my 7970 because it had coil whine.
GTX680 really isn't really an option, because the cheapest version, the one I have linked, costs 120$ MORE than the best 7970.
Should I switch my 680 for any of the http://www.tms.co.il/search/?q=gtx670 OR should I buy the http://www.tms.co.il/product/11822 ? Which one should work the best?
Playing CS:GO, Bf3, BF4, Crysis 3, Hitman Absolution, Far Cry 3, Dirt 3, Sleeping Dogs, Watch Dogs etc, but mainly and mostly BF3 BF4, H:A and CS:GO.
Which one should work the best? stock for stock the 670 out performs the 7970 as I heard, but not the GHz edition, and the GHz edition that I linked is what I will buy and overclock more, but how will it compare to nVidia's 670 with overclock? Heard ATI can OC more than nVidia
More about : buy gpu hours minute
Related ressources
Sumukh_Bhagat said:
Get a 7970 Ghz Edition. Its very awesome Card.
But.. I play mostly BF3 and I have some bad experience with the 7970 for coil whine...
And BF3 is nVidia optimised.
But the 680 costs wayy too much for me
esrever said:
7970 GE is faster than the 680 in bf3.
Even when both are OC'ed?
And in other games?
And it took AMD like 4 month to reclaim the best GPU over the 680, and the new beta driver already got some nice BF3 boost..
Graphics card Master
Overclocking Expert
I have no idea with specific cards but they shouldn't have much noise unless you buy the ones stock fans.
Nvidia drivers don't usually improve performance even if nvidia claims they do. The newest haven't been tested but that chart was with nvidia's drivers that they claim had a 25% boost in bf3.
Exactly.. How will I know it wont suddenly be 100FPS instead of 70?
Overclocking Expert
because that less likely than if the card suddenly gets 20 fps with the new drivers.
OP, sounds like you've already made your decision.
The 7970 is a generally better card in spite of constant driver optimizations on both sides.
If you're worried about fan noise, you can try to find a quieter version (I like my Gigabyte OC edition--pretty quiet overall) although most graphics cards are going to get loud when under heavy load--just the nature of the beast.
Best of luck in picking your card.
ESrever is ight. The difference is the ghz editions have been tested and certified at a higher speed rating, since OCing beyond the stock clock is dependent on the quality of each individual card (one of the reason performance cards are more expensive even though they use the same chip--they've been tested and passed at higher ratings).
Basically you're paying for a stamp that says "This card will run at least xxx faster than it's non-ghz counterpart." Doesn't make the chip itself any faster, just how it's programmed to run which you can do on your own with OCing.
My regular Gigabyte is stable at 1125, and runs just fine at 1250 with only a minor voltage bump.
Ok. Now, one last thing.
OC'ed 680 vs OC 7970, will the 7970 still beat it?
esrever said:
the 7970 beats it even more.
And do you (guys) think it will stay that way? Or will the 680 ones again claim its glory?
Because I have used the 7850 Gigabyte, OC'ed it like a monster and played High at like 70FPS, and I really liked that.
So I guess I had good experience with AMD. But nVidia is disappointing with theyr 680, it doesnt OC that much, gets hot, loud and annoying at times
Overclocking Expert
the 680 will most likely never be the fastest card again. The difference is pretty sizable and its unlikely nvidia will get there. They can probably pull closer but not likely to take a definite lead.
The 680 shouldn't be all that bad tho, its most like you had a bad card. Even tho it doesn't OC well, it shouldn't be too hot and loud.
Ok. So the 7970 for SURE? :D
Thanks so much guys for awesome and fast replys!
Overclocking Expert
well, you can get either but the normal one should OC to pretty much the same performance if you OC it yourself. The better ram isn't much of an issue since the 7970 has more than enough memory bandwidth to start with.
I thought Ill just get the safer option for 25$ more, and asked them to save the GHz edition.
