Solved
About to buy parts need help
  • New Build
  • Corsair
  • Systems
  • Product
Last response: in Systems
January 20, 2013 4:17:40 AM
This is the computer I've come up with, but I would like to cut it down to under 1000. I live in Australia, so I'm buying from pccasegear.com. Thanks.
CPU- intel core i5 3570k= $229
Mobo- asrock extreme 4= $139
Graphics card- Asus Radeon hd7850= $235
Ram- Corsair CMX8GX3M2B1600C9 DDR3= $49
HDD- seagate barracuda 2tb= $99
SSD- sandisk extreme 120gb= $109
PSU- corsair cx-750 modular= $115
Case- Corsair Carbide 500R (white)= $145
OS- windows 7- $95
Optical drive- samsung SATA DVDRW= $19
total- $1234
More about : buy parts
Best solution
January 20, 2013 4:21:44 AM
You're getting ripped off on the GPU. buy a 7870 for the same price. also you're spending too much on the case, check out some options from nzxt like the lexa s or the tempest 410 elite. You might be able to NOT pirate windows seven and MAYBE put that money towards a gpu or something. also a CX600 is like 60$ cheaper and will be fine for you. other than that looks nice
January 20, 2013 4:32:07 AM
^ listen to him 7850 is usually lower than 235 aud
and case is too pricey, get 300r or anything cheaper as it adds nothing to performance
i hate to say this because i am a fanboy of corsair LOL
cx series is okay but less quality, get at least TX/HX series
or switch to XFX 650/750 instead
http://whirlpool.net.au/wiki/psu_manufacturers
read this to make sure who manufactures the PSU
m
l
January 20, 2013 4:33:12 AM
I bought a CX 750 Modular for a 3770k and a 670. ;p
m
l
January 20, 2013 4:34:46 AM
The cx600 is only 20 dollars cheaper in Australia. And I can get the a sapphire Radeon hd hd7870 for 30 dollars extra.
m
l
January 20, 2013 4:35:12 AM
^ i said CX is okay, but this community exists to make sure people get the most they can get for their budget
m
l
January 20, 2013 4:35:42 AM
Get the 7870, It's the diff between maxing out games and not.
m
l
January 20, 2013 4:43:06 AM
Unfortunately that power supply is not available in Australia
m
l
January 20, 2013 4:46:32 AM
Some brands for psu's you'd be happy with (also anything over 400w is fine for you): Corsair, XFX, Cooler Master, NZXT, Rosewill (only the good rosewills [the expensive ones, lol]), seasonic, and some antecs.
m
l
January 20, 2013 4:47:30 AM
What do you think the the Coolermaster storm enforcer or the Coolermaster HAF 912 combat, both around $80. Or a different case.
m
l
January 20, 2013 4:48:08 AM
Thanks ill have a look
m
l
January 20, 2013 4:51:32 AM
Are the Coolermaster GX or the extreme 2
m
l
January 20, 2013 4:56:00 AM
Coolermaster is on the BOTTOM of the ok psu list. go for corsair xfx or seasonic
m
l
January 20, 2013 4:56:27 AM
^ this is 100% true
m
l
January 20, 2013 4:59:23 AM
Lol wth man. xD
m
l
January 20, 2013 5:02:41 AM
Haha, thanks for the help guys.
m
l
January 20, 2013 5:03:00 AM
Best answer selected by Mapsx15.
m
l
January 20, 2013 5:08:12 AM
No problem man :)  enjoy your build
m
l
