Need advice on new build
Hey guys i just wanna make sure that all my components will be compatible and i would like some reviews on the build and what i could improve on, i will be getting xspc 720 360
Basket: http://www.scan.co.uk/savedbasket/41977237bbbd44dc875e1d7d69abb402
(need advice asap)
8 answers Last reply
More about need advice build
    (need advice asap)
    everything seems to be good! got yourself a good comp :)
  2. Hi :)
    I would spend MORE on the graphics card (if you are a gamer as that one wont Ultra anything ) and less on the PSU (any decent 500 will do)
    All the best Brett :)
  3. Brett928S2 said:
    Hi :)
    you do realize your talking about a 670...and ONE monitor...only 1080p...that will ultra EVERYTHING and no not less on the psu thats a horrible idea.
  4. If you want you can get a 7970 with amds new drivers it beats a 680 in everything and also stick with your PSU because in the future you MAY want to upgrade to another gpu and buying good parts now will save you from spending more in the future.
    Hi :)
    Its a decent MID range card (670)... I sell them in my shops...
    If it could Ultra everything with everything turned on , why would they sell 680s, or 690s ?
    And ANY decent make 500 psu will be fine for a single graphics card.... even my 7990 only uses an 850 OCZ...
  6. Brett928S2 said:
    Hi :)
    They sell the 680's and 690's for people with multiple monitors, people who have 120 hz monitors and want more than 60 fps, and people who want to future proof their system. There are probably many more reasons...
  7. Is it worth getting gtx 680 then? will it be a better option?
  8. This topic has been moved from the section CPU & Components to section Systems by Mousemonkey
New Build Compatibility Components New Build Systems
