First gaming build help
Does this look ok for a first time gaming build?
Are all the parts compatible+ will they fit in the case i picked?
Thaks a bunch!
http://pcpartpicker.com/p/yIX7
1 answer Last reply
More about first gaming build help
  1. This is what I would suggest if you don't want to overclock.
    CPU: Intel Core i5-3570 3.4GHz Quad-Core Processor ($209.98 @ SuperBiiz)
    Motherboard: ASRock H77M Micro ATX LGA1155 Motherboard ($69.99 @ Newegg)
    Memory: Mushkin Blackline 8GB (2 x 4GB) DDR3-1600 Memory ($35.57 @ NCIX US)
    Video Card: Sapphire Radeon HD 7950 3GB Video Card ($304.37 @ NCIX US)
    Case: Cougar Volant (Black) ATX Mid Tower Case ($49.98 @ Outlet PC)
    Power Supply: Corsair Builder 600W 80 PLUS Bronze Certified ATX12V Power Supply ($39.99 @ Newegg)
    Optical Drive: Asus DRW-24B1ST/BLK/B/AS DVD/CD Writer ($19.98 @ Outlet PC)
    Operating System: Microsoft Windows 7 Home Premium SP1 (OEM) (64-bit) ($89.98 @ Outlet PC)
    Total: $819.84
    (Generated by PCPartPicker 2013-01-21 10:14 EST-0500)
    If you do want to overclock, go with this.
    CPU: Intel Core i5-3570K 3.4GHz Quad-Core Processor ($219.99 @ Newegg)
    CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler ($24.99 @ Newegg)
    Motherboard: ASRock Z77 Pro3 ATX LGA1155 Motherboard ($87.55 @ Newegg)
    Total: $869.40
    (Generated by PCPartPicker 2013-01-21 10:18 EST-0500)
    The "k" version of the i5-3570 is overclockable and the non-k is not. So either go with the k version and Z77 chipset or skip the OC and get the H77 chipset for the non-k CPU and save some cash. The MSI board you suggested is way overpriced. I was able to redistribute your budget to get appropriate needs for GPU. The 7950 will surpass the 660 in any game and can be overclocked for better specs.
    This is the MSI Twin Frozr but similar to the GPU you had listed.
    http://www.techpowerup.com/reviews/MSI/GTX_660_Twin_Frozr_III/22.html
Build Gaming Cases Systems Product
