What cmos battery is fitted to packard bell mcp73 motherboard
What kind of CMOS battery is fitted to a Packard Bell MCP73 motherboard, please?
6 answers Last reply
More about what cmos battery fitted packard bell mcp73 motherboard
  1. You can open the case and look at the battery. It will have a number on it which you can use to cross reference to other manufacturer's batteries. You can also just bring it to your nearest radio shack or battery store and match it up to one of their batteries.
  2. Hi :)
    A standard 2032
    All the best Brett :)
  3. Brett928S2 said:
    Hi :)
    A standard 2032
    Thanks Brett, I even have a couple of spares!
    Regards,
    tristar
    Thanks, Hawkeye22, I just wanted to know in advance so that I could have a spare ready.
    Regards, tristar3
  5. I've been working with computers since the early 80's. I think I've replaced 2 batteries in all that time. If you need spares, you may have a problem.
  6. If it's the good old 2032, then I have no problem, thanks for your help.
    tristar3
Battery Packard Bell CMOS Motherboards Windows 7
