Need help in choosing new GPU for my system
Hi all,
So about a week ago my gpu fan died (a GEforce gt430) and figured now is a good time to upgrade but I have a couple of concerns the biggest being if my psu can handle a new or upgraded card (not 100% sure how it works). These are my specs
PSU: ISO 480pp 420w max, single 12v rail at 18a (fairly sure)
Motherboard: Foxconn H67Mv
Ram: 8 gigs
CPU: Intel i5-2400
OS: Win-7 64bit
So far i've considered the GTX 550 ti as well as the ATI Radeon 5770 and 5750. I'm willing to upgrade my PSU if you think it's greatly beneficial/crucial. I don't intend to overclock and my budget is somewhat strict at a maximum of $250 (less would be very nice). I intend to use the new gpu for mostly single-player gaming so something that can run a modern game at mid-high levels with good fps would be awesome.
Let me know if you need any more information,
Thanks in advance! :D
More about : choosing gpu system
I would definitely upgrade my psu if I was you, i would recommend a corsair tx650v2 since it is at 650w and you get 5 year warranty. Then I would go for whatever your preference is amd or nvidia, if it is amd you want I would go for a 7870 or 7970. And if it is amd you want get it from sapphire they are the best
Thanks a lot, I'll certainly consider it :)
