Sapphire radeon hd 6670 1 gb ddr5 vga vs diplay port model
December 7, 2012 4:23:07 AM
Hi Experts,
I bought a sapphire hd 6670 1 gb ddr5 today. I believe it is faster thatn the 2 gb ddr3 model. It has vga, dvi and hdmi slots in it. i saw another model in internet which has dvi, display port, hmdi in it. what is the difference. should i ask them to replace mine with the display port model. otherwise i think both have the same configuration. please help.
a b U Graphics card
December 7, 2012 4:34:56 AM
You listed the difference. And unless you have an expensive monitor you won't ever need to use the display port. Yes the 1GB GDDR5 version is faster.
Most older monitors are hooked up with VGA although DVI is better, it seems they might be replacing VGA, that's all.
m
l
December 7, 2012 4:56:45 AM
Thanks for the reply. Also how do i verify if my video card is 1 gb ddr5 as there is a possibility that they could have given me ddr3..where can i see this in my computer?
m
l
a b U Graphics card
December 7, 2012 5:18:56 AM
It should say on the box it came in.
m
l
