Hi everyone,
In the past 2 days I've had some really bizarre things happen with my graphics cards, and I've reached the end of my tether, so I thought I'd seek some help.
I have 2x Gigabyte 6970s running in Crossfire that have been on the 12.4 display driver since they were released, back in May. I got Far Cry 3 last week and to get a performance boost, I upgraded to 12.10 (the latest 'release' build). I then read that the 12.11 Beta drivers provided a lot better performance boost for FC3, so I again, updated to 12.11.
Everything went smoothly for about 3-4 days.
Then I restarted my computer and started getting what people have been calling the 'Black Screen of Death'. Windows will boot, it will show the 'Welcome' screen, then it will go to a black screen with a cursor, but no desktop. It will sit there indefinitely. I booted into safe mode and uninstalled the drivers, cleaned it out with Driver Sweeper, then went back to 12.4. Everything worked perfectly.
I then proceeded to try the new drivers with only one card, I tried both as a single card, I tried swapping them around, I made sure they were seated, cables were seated correctly etc.
The problem, which was schizophrenic at first, has at least gained some consistency. Now, if I install the 12.10 drivers, I'll get the black screen issue. However, if I update STRAIGHT to 12.11 Beta from 12.4, I won't get the black screen, but my Catalyst Control Center won't open.
Now, I've been looking around for ages and can't really find a fix that works for me, but I was wondering if anyone has experienced anything similar, and if you have tried something that worked that I haven't seen yet.
Right now I think I'm just going to be waiting for the next stable release, and hoping for the best
For reference, here are my full PC specs:
Gigabyte Z68XP-UD3 Mobo
Intel i7-2700K CPU
G.Skill Ripjaw 16GB DDR3 Memory
2x Gigabyte HD6970 in Crossfire (stock, not overclocked)
OCZ Agility 3 120GB SSD (All drivers are running off that)
Thanks in advance
Intel i7-2700K CPU
Thanks in advance
