I have a power supply with 400w and it only has one 6-pin PCIe so if i buy a GeForce GTX 560 Ti would the video card only work with one 6-pin PCIe or would it need two 6-pin PCIe for the card to work???
Yes you need 2 x 6-pin PCI-E power connectors otherwise the card won't work at all. Note that you could also convert some of your molex plugs to PCI-E they sell adapters for that but I'm not sure I would do it on a cheap power supply. What's the brand and model of your PSU? They also recommend a 500-Watt PSU for that card. If you plan to add a nice video card in your system I would suggest you replace the PSU as well if you don't want to fry the card. Get a good brand like Corsair, Antec, Seasonic, etc...
Here's a good quality one, good bang for the bucks also:
right now i have
CPU AMD Athlon x4 645
HDD 1TB
RAM 6GB
Resolution 1280x1024
War of roses, Shogun TW, Star trek, Red orchestra 2, World of tanks, world of plains.
nd youre albanian right?
You need at least a 500w Power Supply to support your GTX 560 Ti. If you have a lot of hungry components you might want to get a 650w or higher. Don't scrimp on your power supply or you'll just have to upgrade it later on. Do it right now and avoid issues that come from being underpowered. I saw this model on New Egg.
CORSAIR Builder Series CX500 500W
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139027
a lot of people have recommended me those PSU but there out of my budget right now but thanks a lot man
