Closed Solved
Sli gigabyte gtx 670 power consumption
I'm only buying one for now, but I was wondering if I could run sli in the future on this psu: http://www.newegg.com/Product/Product.aspx?Item=N82E16817438006.
I want to slightly overclock my 3570k cpu along with this so would this be unsafe?
6 answers Last reply Best Answer
More about gigabyte power consumption
  1. Well they need ~325W on peak .Add some oc and they pass that limit. Edit : (they can go even higher)
    That link expired but i suggest you getting a 650W Psu.
    Xfx Pro CoreEdition 650W 69.99$
  2. Best answer
    nVidia itself recommend 500W for a single 670.
    http://www.nvidia.in/object/geforce-gtx-670-in.html#pdpContent=2
    For testing conducted for SLI 670, the resulting system consumption for SLI is 433W of which 293W are attributed to the gpu cards.
    http://www.guru3d.com/article/geforce-gtx-670-2-and-3way-sli-review/4
    GeForce GTX 670 - On your average system the card requires you to have a 500~550 Watt power supply unit.
    GeForce GTX 670 2x SLI - On your average system the cards require you to have a 700 Watt power supply unit as minimum. Remember, if you are going to overclock the GPUs or processor, then we do recommend you purchase something with some more stamina. The minute you touch voltages on the CPU or GPUs, the power draw can rise real fast and extensively.
    All points out to 750W being more than enough.I recommend this one http://us.ncix.com/products/?sku=62224&vpn=P1750BNLG9&manufacture=XFX&promoid=1257
  3. Well 750W is a bit to much :D and that 650W i linked can deliver up to 815W if needed. Thing that his system will never ask the PSU to do it!
  4. o.k. but still GeForce GTX 670 - On your average system the card requires you to have a 500~550 Watt power supply unit.
    GeForce GTX 670 2x SLI - On your average system the cards require you to have a 700 Watt power supply unit as minimum. Remember, if you are going to overclock the GPUs or processor, then we do recommend you purchase something with some more stamina. The minute you touch voltages on the CPU or GPUs, the power draw can rise real fast and extensively. http://www.guru3d.com/article/geforce-gtx-670-2-and-3way-sli-review/4
  5. Best answer selected by Fyuturistic.
Graphics Cards Power Consumption SLI Gigabyte Graphics Product
