Hi all, I'm planning on buying a computer that I hope will last (in terms of reliability and specs/speed) me through three or four years of Uni, with the potential to upgrade components later if need be. The main uses will be programming, 3D work (modelling, rendering, etc.), image editing and a bit of gaming. At the moment the component list is looking like:
CPU: Intel Core i5-3470 3.2GHz Quad-Core Processor ($263.00 @ PC Force)
Motherboard: Gigabyte GA-H77M-D3H Micro ATX LGA1155 Motherboard ($129.00 @ Computer Lounge)
Memory: G.Skill Ripjaws X Series 8GB (2 x 4GB) DDR3-1600 Memory ($89.00 @ PC Force)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive ($99.42 @ Aquila Technology)
Video Card: Asus GeForce GTX 650 Ti 1GB Video Card ($259.00 @ Computer Lounge)
Case: Corsair 200R ATX Mid Tower Case ($103.50 @ PB Technologies)
Power Supply: SeaSonic S12II 520W 80 PLUS Bronze Certified ATX12V / EPS12V Power Supply
Optical Drive: Samsung SH-222BB/BEBE DVD/CD Writer
Other: ASUS PCE-N15 Wireless Adapter ($45.00)
Total: $987.92
(Generated by PCPartPicker 2013-01-23 20:40 NZDT+1300)
Budget Range: The above system is currently sitting at around NZ$1250, and I don't want to go much higher
Approximate Purchase Date: In the next couple of weeks
System Usage: Programming, 3D work, gaming, photo editing
Parts Not Required: Keyboard, mouse, speakers, OS, monitor
Preferred Website for Parts: More than likely will be buying from PBTech here in New Zealand (pbtech.co.nz)
Overclocking: No
OS: I'll be multi-booting between Windows 7 or 8 and a couple of Linux distros (mainly Ubuntu or Mint)
As well as just checking that all the components should work fine (and that I'm not forgetting anything essential), I am looking for some feedback - is anything over/under-kill? I'm also not sure about what cooling will be sufficient. The Corsair 200R includes 1 front-mounted 120mm fan and 1 rear 120mm fan (source), but as this is my first custom desktop, I am not sure whether I need to get any extra fans (I'm not going to be overclocking). Also, are there any down-sides to getting a case with so many fan mounts, particularly if several are going to be left empty?
Cheers.
Total: $987.92
Overclocking: No
Cheers.
