CPU: Intel Core i5-3570k 3.4Ghz Quad Core
GPU: AMD Radeon HD 7970
RAM: Corsair XMS3 12GB (3 x 4GB) DDR3
Motherboard: ASRock Z77 Pro3 Motherboard
HDD: Western Digital 1TB Black 7200rpm 6gb/s
P. Supply: Coolmax 240 Pin 900w
Case: Cooler Master HAF 912 ATX Mid Tower Case
Optical Drive: LG GH24NS90 DVD/CD Writer
OS: Windows 7 Professional 64bit
I need cooling, does the Hyper 212+ work with the CPU I chose? What cooling system should I get?
Is this a decent build? Out of 10, what would this be? Anything I should improve? I was told it still wouldn't achieve 120+ FPS with this build, what should I change?
Which parts should I overclock?
Should I drop the 7970 for an NVIDIA 690 or 680?
