NEED FAST HELP
hi,
i need a good advise for purchasing a graphic card.
the problem is i don't know which one from below one to choose:
http://www.koyos.ro/computere-si-servere/componente-pc/placi-video/placa-video-asus-nvidia-geforce-gtx-660-2gb-gddr5-980-6008mhz-192bit.html
http://www.koyos.ro/computere-si-servere/componente-pc/placi-video/placa-video-gainward-nvidia-geforce-gtx660ti-2gb-gddr5-915-3004mhz-192bit-2b-borderlands-ii.html
http://www.koyos.ro/computere-si-servere/componente-pc/placi-video/placa-video-gigabyte-nvidia-geforce-gtx670-2gb-gddr5-256-bit.html
Zotac Nvidia GTX 580 AMP2 Edition, 3 gb ddr5, 384 biti (second hand from a friend - price close to gainward)
it will be used on 27"monitor with 3D or 32" TV or bigger
if the difference between the 580 and 670 is little, i think i will go with 580
please send me an mail with the answers
best regards,
giox39
1 answer Last reply
More about need fast help
  1. if the difference between all 4 is few fps, i will go with the cheapest and that is Asus the first one
Graphics Cards Graphics
