Solved
Problem with new home build?
Last response: in Systems
Homebuilt system Authority
Motherboard Master
see if there any fault led on. check the mb bios rev and the cpu you installed. a lot of newer mb need bios update to turn on some times. (x68 and ib cpus.) make sure the mb not shorting out to the mb tray or the cpu heat sink or the mb i/o shield. if you think there a short try bread boarding it outside the case. make sure the 4/8 pin pci power connector plugged in. on the pci power make sure your using the right power cable and not the 6 plus 2 power cable for the video cards.
Related ressources
I probably could've given more information, sorry... the motherboard has one green light that does turn on when I turn the power supply on, and it has two little switches (tpu and cpu or something)
here's a list of what I got
cm storm scout 2
Asus p8z77-v77 pro versions
Samsung 840 250gb sad
cm silent 700 pro
mushkin 2 x 4gb ddr3 1333
Intel i5 3570k
Asus DVD burner
no video card yet
so my friend thinks is the PSU and say it may be faulty,I'm very disappointed this build wouldn't work... I will definitely try any of the suggestions given... thank you guys
sorry I forgot to mention those switches have a green light that turns works when I use the switches, and one last thing, the PSU fan doesn't even spin when I turn it on so to me (still a novice but just guessing) it sounds like the PSU is the problem. A motherboard short sounds like another one
and I actually did try bread boarding it before I built it and no fans came on but I disregarded that and thought maybe something wasn't plugged in properly
Best solution
Motherboard Expert
Coolermaster makes very poor quality PSU's. Its usually recommended that you replace them if you have one. They cannot deliver the stated wattage and fail very commonly. Replace it with something from antec, XFX, Corsair, seasonic.
You only need 500w for this system. Look into a corsair cx500 or cx600.
Motherboard Expert
The point i'm making is, the PSU won't produce 700w. Coolermaster has been under scrutiny for faking their 80+ certified labels. They are low quality PSU's known to easily fail. If it craps out it can easily take the rest of your system with it.
Also, 500w is enough to run any single GPU.
