Sapphire 7750 800mhz power connector?
Does the sapphire HD 7750 require a 4/6 pin power connector? I checked my computer and I only have two 4 pin (female if the makes the difference)
...yes as you can tell I'm kind of confused.
If it does require a 6 pin power connector then what kind of adapter would I need to buy? Thanks for helping in advance again:love:
2 answers Last reply
More about sapphire 7750 800mhz power connector
  1. 7750s pull less than 60 watts and do not require any connectors from the PSU. GPUs do not use 4 pin connectors anyway. If they are a cube its for your motherboard, if the pins are all in a line its molex for HDD/DVD etc
  2. Oh okay! So then I don't have to worry then, I can just fit it into the slot and it'd work without any other cables, etc
Graphics Cards Power Sapphire Graphics
