Archived from groups: alt.video.laserdisc (More info?)
"computeruser" wrote:
>I am considering a sound card for importing Laserdisc data into my PC for
>editing.
> http://www.turtlebeach.com/site/pr [...] /catalina/ >
> Is this what I want for my computer to interface with the optical out on a
> laserdisc player??
Somebody correct me if I'm wrong, but the card appears to have only analog
stereo *inputs* and a digital audio input.
The card you link to will be fine for outputting multi channel audio say
from you pc's dvd player/burner but not importing from an external source.
You'll be able to record the audio from simple stereo laserdiscs either
through the analog or digital input or possibly DTS 5.1 encoded laserdiscs
through the digital input only but judging from the cards' specs, it would
probably downsample the DTS bitstream to 24 Bits at 96KHz. To get the AC-3
track off the laserdisc from a DD 5.1 soundtrack, you'd no doubt need an
external RF Demodulator between your laserdisc player and the PC's sound
card. You'd also need some higher end audio editing software like Wavelab or
Soundforge, something that handles and edits multi track audio.
To be honest, I'm not even sure there's a consumer audio card that will
easily and effectively import a laserdisc's multi channel audio. This kind
of hardware and software isn't something you can get at a Best Buy or
similar mass consumer electronics outlet. I do know that there are sound
cards made by Arc, Siena and a few others in the $400 - $600 buck range that
are multi-channel analog/digital that might work for your needs.
I would strongly suggest contacting a local music store, the bigger the
better like say a "Guitar Center" or "Sam Ash Music " as they have dedicated
a/v authoring departments that sell more isoteric hardware and software more
suited to your needs along with people that can help you best.
Actually, it depends if "computeruser" is going to import DD5.1 or
just the Digital Audio track like I do. Personally, I would hold out
for a card that doesnt resample the data either way. This is a must
if you want to cap the AC3 tracks (and even then your going through
alot of hoops to get it but forking out for an RF modulator from what
Ive read). Im pretty sure the cards featuring the VIA Envy24HT
chipsets dont resample, but the only card of that chipset that I know
up with Optical Digital in for recording is the Terratec Space and
Universe cards. In a post somewhere back someone mentioned the
CMI8738 chipsets as also not resampling.
If all your wanting is the PCM digital audio track then this card
should work. It will likely resample the input, but you probrobly
wont even notice.
On Sun, 23 Jan 2005 01:50:43 GMT, "TB" <partyslammer@socal.rr.com>
>>editing.
>> http://www.turtlebeach.com/site/pr [...] /catalina/ >>
>> laserdisc player??
>T.B.
