Tom's Hardware > Forum > Mobility Brands > Nokia > 6230 and Bluetooth problems
Forum Mobility Brands : Nokia - 6230 and Bluetooth problems
Archived from groups: alt.cellular.nokia (More info?)
Hi
If this has been discussed else please advise !
I have W XP + SP2, have updated the drivers so Widicomm is running
correctly.
Have installed Nokia PC suit 6.41.6
After installation the phone is recognised correctly, but later (PC
Rebooted etc) cannot communicate. The Bluetooth seems to know the
phone is there.
Very Annoying and time consuming.
Webfoot0
Sponsored Links
> correctly.
> phone is there.
I have exactly the same problem on two XP sp2 machines, all I can tell
you is I have no problems with Windows 2000 Professional using the
drivers supplied with the bluetooth dongle, (widcom again)...
Hopefully either Nokia or MS are working on it...
ajoliver
Reply to Anonymous
We have similar problem. After reboot of the pc the connection works
just fine until u walk away from your computer and then come back. Then
u need to restart the computer again to get bt to work.
But we find one solution to get it working without bootin the pc. You
just need to kill 2 processes in next order and you can have connection
again.
1. NclTray.exe
2. ServiceLayer.exe
After that u can start NclTray again and it can reach the phone again.
This seems to work at least with Belkin BT adaptors
TeroX
Cell Phone Forums: http://cellphoneforums.net
View this thread: http://cellphoneforums.net/t171668.html
Reply to Anonymous
I had the same problem until I found:
http://www.canyon-tech.com/FAQ/Sho [...] SB_Adapter
and followed the instructions there.
Seems to be working without rebooting all the time. We'll see...
....Bob
<waterwy.1.webfoot@spamgourmet.com> wrote in message
news:hg92511bhlnfs6j0r4i389hpf6ku8tduf6@4ax.com...
> Hi
> correctly.
> phone is there.
> Webfoot0
Reply to Anonymous
There are 1289 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
