What power supply to get
Last response: in Systems
Hello,
I wanna get a custom built pc for gaming with this specs and this case:
*Corsair Graphite Series Steel Silver 600T Mid-Towe Computer Case (CC-9011020-WW)
*Intel Core i5-3570K Quad-Core Processor 3.4 GHz 4 Core LGA 1155 - BX80637I53570K
*EVGA GeForce GTX 670 SuperClocked 4096MB GDDR5, 2x Dual-Link DVI, HDMI, DP, 4-Way SLI Ready Graphics Card (04G-P4-2673-KR)
*Corsair Vengeance Blue 16 GB DDR3 SDRAM Dual Channel Memory Kit CMZ16GX3M4A1600C9B
*Seagate Barracuda 7200 1 TB 7200RPM SATA 6 Gb/s NCQ 64MB Cache 3.5-Inch Internal Bare Drive ST1000DM003
*ASUS P8Z77-V PRO/THUNDERBOLT LGA 1155 Intel Z77 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard
Ok, so the thing is that I am no expert in power supplys so I would really appreciate if you guys can help chose a really good one. Thank you
More about : power supply
Homebuilt system Expert
If you are going to stick with a single card, a 550-600W will do fine.
http://us.ncix.com/products/?sku=59615&vpn=P1550SXXB9
If you are thinking of SLI in the future then go 700-750W
http://www.newegg.com/Product/Product.aspx?Item=N82E16817703027
If that PCP&C PSU is too high for your budget, the Corsair 750TX series are not quite as reliable but good.
A few suggestions on your build:
Go with 8GB RAM, it is plenty for gaming.
That case is super expensive, unless you really like it.
Motherboard is overkill.
7970 is a better performer over the 670.
CPU: Intel Core i5-3570K 3.4GHz Quad-Core Processor ($219.99 @ Newegg)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler ($29.99 @ Amazon)
Motherboard: Asus P8Z77-V LK ATX LGA1155 Motherboard ($124.99 @ Newegg)
Memory: Patriot Viper 3 8GB (2 x 4GB) DDR3-1600 Memory ($38.50 @ NCIX US)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive ($69.99 @ Amazon)
Video Card: Gigabyte Radeon HD 7970 3GB Video Card ($399.99 @ Amazon)
Case: Antec Eleven Hundred ATX Full Tower Case ($89.99 @ Newegg)
Power Supply: XFX 550W 80 PLUS Bronze Certified ATX12V / EPS12V Power Supply ($53.99 @ NCIX US)
Total: $1027.43
(Generated by PCPartPicker 2013-01-25 20:08 EST-0500)
Thanks man, really helped me there!! About the case I really like and I love corsair so I think I'm getting that one and I'm gonna take your advice on the 8 gb of ram. THANKS A LOT!!
