Hi guys!
I need some good advice desperately. Two days ago I got a new corsair 600tm case and and antec khuler 620.
Excitedly and very carefully, I placed all my components in the new case and attached the cooler, I really took my time and tried to do it properly and neatly. Anyway it looks absolutely stunning, and I was so proud...
Until I plugged it in, it started up into windows, and then I got a bsod. I checked all the plugs in the case and one of the 6pin connectors on my Gpu was not in properly, and it seemed to work fine.
The next (yesterday) morning I tried to switch on the pc and it booted into windows and while all the programs were loading it froze solid. Had to do a hard reset, with the same result. Then it just wouldn't start properly at all, it tried to start over and over a couple of times, and then it would seem like it was on,the fans were spinning etc, but no picture, no bios screen... Tried with onboard graphics and no dice either. I tried resetting the CMOS and unplugging and plugging back in all the plugs, tried a few more times and eventually I got it to boot into windows and it was fine, I played many hours of battlefield 3 and some borderlands 2 too.
I ran core temp, getting nice low temps, did a burn test to check CPU, and passed fine.
My question is WTF is going on!!!! I have had similar problems twice in the past. First time i had the problem where it would start for a second and restart. Forever. Turned out to be the mobo. 6 months later ( last month) it happened again, this time it turned out to be PSU. And now this, bad luck Brian has nothing on me!
I have just got a new psu and mobo over Christmas....
My full specs are:
I5 2500k
2x 4gb corsair ddr3 1600mhz ram
Msi twin frozr iii GTX570
2x 500gb hdd
60gb ocz ssd
ASrock z77 extreme4 (1 month old)
Antec khuler 620 ( 2 days old)
Corsair graphite 600tm (2 days old)
Silver stone 750w 80+ silver (1 month old)
What i want to know is:
Does the fact the I played some pretty stressful game for hours on end mean that my psu, CPU and Gpu are fine?
What could the culprit be here? I have a spare mobo, so I could try that... But the khuler was such a mission to fit, don't feel like going through that again if I don't have to...
Thanks for taking the time to read this, any help will be appreciated...
My full specs are:
I5 2500k
2x 500gb hdd
60gb ocz ssd
