I'm putting together a PC that will do everything for the foreseeable future, meaning it will run any game, pro-level video/sound editing/recording, 3-D modeling/rendering etc. at the highest settings without a hitch for the next few years for as cheap as possible. I don't plan on overclocking till I need to. My main monitor will be around a 40inch LED, 1080p, 60htz TV connected through HDMI that I'm still shopping for.
I'm looking for the most bang for the buck. Aren't we all?
I'm going with AMD's FX-8350 mainly because it's fastest out of the box and it's closest competition is the i7 which is $100 more expensive.
I'm also going with the Gigabyte Radeon HD 7850 2GB Video Card since the next best thing seems to be a substantial price jump.
Each of those are $200. My original budget was $500 and I'm also getting a 128gb ssd and 16gb 1600 DDR3, which brings my total close to $600 without a Motherboard. I already have a 600watt power supply and a case. Am I missing anything I need?
I was going to go with the Gigabyte GA-970A-DS3, but I've been seeing posts talking about compatibility issues with the 8350. Apparently a BIOS upgrade fixes the problem, but can this lead to issues down the line?
Any bottleneck or compatibility issues with my CPU/GPU/Mobo combo?
What motherboard would be best and what motherboard would be best for around $100?
Thanks for your help!
Gino
Gino
