Tom's Hardware > Forum > Mobility Brands > Nokia > 6230 Wont Identify Calls Help!!
Forum Mobility Brands : Nokia - 6230 Wont Identify Calls Help!!
Archived from groups: alt.cellular.nokia (More info?)
The answer to this is probably so obvious, but I can't find it.
I've just bought a new 6230 on Orange PAYG.
It won't identify or store an incoming call.
If I use the menu to access the call registers, there isn't a "missed
calls" or "received calls" option!!! the menu numbers start at 3 and
go to 9.
If I dial it with my old mobile, even though the 6230 knows the
number, I get "missed call no number" on the 6230.
What do I need to set?
Sponsored Links
On Thu, 07 Apr 2005 13:36:44 +0100, Martin L
>go to 9.
You need to phone Orange CS and ask them to send you an update.
John
Reply to Anonymous
Cheers for the reply.
The problem went away when i removed the battery to extract the memory
card.
This was after i emailed Orange, and had no reply.........
On Tue, 12 Apr 2005 18:54:13 +0100, John H
>John
Reply to Anonymous
There are 962 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
