Help Please!! BSOD with new PC - AMD FX8350, AsRock Extreme4
Hi,
I recently purchased my new PC. Its an AMD FX-8350, paired with AsRock 990FX Extreme4 Mobo, Corsair Vengeance DDR3 1866MHz 32GB, Sapphire HD 7970 VAPOR-X GHZ Edition 3GB GDDR5, Corsair Storage Solutions 120GB 2.5" Solid State Disk Drive Neutron Series and Corsair HX 1050W Modular PSU.
So far, I have installed Windows 7 Ultimate SP1, flashed the BIOS, installed Windows Updates, installed all drivers for the mobo and video card, and still, every 15 mins I get the BSOD. I have spent all weekend trying to fix the problem to no avail. Not sure if its because any of the parts I have chosen here are incompatible but I have checked to make sure the CPU, RAM and mobo all get along and they seems to support each other. Does anyone have any ideas? Any help much appreciated!
6 answers Last reply
More about help please bsod fx8350 asrock extreme4
  1. Have you set the volts to for your ram.
    At the moment I have left the Voltage on Automatic, which happens to be 1.5V
  3. Just a quick point. I have just found this list of compatible memory
    http://www.asrock.com/mb/memory.asp?Model=990FX%20Extreme4
    I notice my ram (Corsair CMZ32GX3M4X1866C10R Vengeance Performance 32GB DDR3 1866MHz) isnt on the list. Although it accepts the frequency, is it possible this is the cause of my woes?
    Thanks again!! :)
  4. If the Problem Does not end, Just Sell that PC, and Buy a New PC. !!!
    Hmm, pretty sure it would be hard to sell a PC that dosn't actually work...
  6. change your ram into 16gb & use 1600mhz ddr3.. asrock not confirm the use of 32gb 1866mhz ram yet for asrock FX990 extreme series, see the memory support list
New Build ASrock Corsair Systems
