Graphics Card Help
I wanna buy a new graphics card but i don't know what one to get. I will mostly be playing BF3/BO2 and want to run at high/ultra settings. my budget is around the 120 GBP. And if possible an Nvidia Card.
Please Help, Thanks.
5 answers Last reply
More about graphics card help
  1. You can get a 650ti for that price :
    http://www.amazon.co.uk/dp/B009KFT2KA/?tag=pcp0f-21
    Just check if you have a decent psu with a 6-pin pcie connector and with ~450w
    But i recommend if possible to spend more 3 our 5 pounds and get a 7850 1GB, it has a much better performance overall(the psu requirements are the same as a 650ti) :
    http://www.dabs.com/products/xfx-amd-radeon-7850-860mhz-1gb-pci-express-3-0-hdmi-core-edition-8DG6.html
  2. I can tell you right off the bat ultra is not happening at that budget unless you are at extremely low resolution.
    And you shouldn't be looking at nvidia if you're on a budget, AMD wins price/performance across the board
    How much would i have to spend to get BF3 on ultra settings on an nvidia card?
  4. A 7850 1GB can do ultra on battlefield 3 at good fps, but if needed a nvidia card, the recommended will be the 660 gtx for :
    http://www.scan.co.uk/products/2gb-msi-gtx-660-twin-frozr-iii-oc-28nm-pcie-30-(x16)-6008mhz-gddr5-gpu-1033mhz-boost-1098mhz-cores-9
    Lowest price you'll find with a good cooling system/brand.
    http://tpucdn.com/reviews/MSI/GTX_660_Twin_Frozr_III/images/perf_oc.gif <---performance of a 660 gtx MSI TF
    http://tpucdn.com/reviews/Club_3D/HD_7850_RoyalQueen/images/perf_oc.gif <---performance of a 7850 1GB
  5. Thanks djangoringo. I will get the 7850.
Graphics Cards Battlefield Nvidia Graphics Product
