Solved
New Build Parts/Performance Check
Last response: in Systems
January 28, 2013 1:47:22 AM
Hey everyone, just wanted to run a quick compatibility/quality check on a new system I'm looking to build. Here's the parts list:
CPU: AMD Phenom II x4 965 Black Edition (3.4) GHz
GPU: HIS IceQ Radeon HD 7870 2 GB
MoBo: BIOSTAR Hi-Fi A85S3 Ver. 6.1 FM2 AMD A85X (Hudson D4) SATA 6Gb/s USB 3.0 HDMI Micro ATX AMD Motherboard
PSU: Antec NEO ECO 620W
RAM: Kingston HyperX Blu 8GB 240-Pin DDR3 1333
Case: Rosewill Blackbone Black Steel / Plastic ATX Mid Tower Computer Case
HDD: Western Digital Caviar Blue 500 GB SATA III 7200 RPM 16 MB Cache
http://www.amazon.com/Western-Digital-Caviar-Cache-Desk...
Everything look good? I'm mainly gonna use it as a gaming PC, will it run these games well?
Kingdoms of Amalur: Reckoning
The Witcher 2
Borderlands 2
Torchlight 2
League of Legends
Assassins Creed III
Also, I'd like to be able to run some games that will be coming out in the future (Splinter Cell: Blacklist comes to mind), will it be able to handle future games as well? Thanks in advance!
January 28, 2013 1:51:57 AM
could you list your budget and location cuz there are improvementz to be made
m
l
Best solution
January 28, 2013 2:28:23 AM
First off your Mobo doesn't support AM3 chips (it's an FM2 chipset). Here is what I'd consider:
CPU: AMD Phenom II X4 965 Black 3.4GHz Quad-Core Processor ($98.79 @ Amazon)
Motherboard: ASRock 970DE3/U3S3 ATX AM3+ Motherboard ($69.99 @ Amazon)
Memory: G.Skill Ares Series 8GB (2 x 4GB) DDR3-1600 Memory ($47.99 @ Newegg)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive ($69.99 @ Amazon)
Video Card: HIS Radeon HD 7870 2GB Video Card ($199.99 @ Newegg)
Case: Cooler Master HAF 912 ATX Mid Tower Case ($39.99 @ Newegg)
Power Supply: Antec Neo Eco 620W 80 PLUS Certified ATX12V / EPS12V Power Supply ($29.99 @ Newegg)
Optical Drive: Lite-On iHAS124-04 DVD/CD Writer ($16.99 @ Newegg)
Total: $573.72
(Generated by PCPartPicker 2013-01-27 23:22 EST-0500)
You can substitute in a different AMD CPU if you like. The ones listed below have additional "Promo" codes that get you $10-15 off!
AMD CPU discounted priced ones.
or
Intel version, but is Dual core, which isn't a bad thing for gaming, but might make a difference for you:
CPU: Intel Core i3-3220 3.3GHz Dual-Core Processor ($129.99 @ Newegg)
Motherboard: ASRock Z77 Pro3 ATX LGA1155 Motherboard ($87.55 @ Newegg)
Total: $610.48
(Generated by PCPartPicker 2013-01-27 23:25 EST-0500)
Intel Mobo has onboard USB 3.0 if you want/need that (used for Front panel ports on case). If so, than I'd recommend a different case that has Front USB 3.0 ports:
$50 - $10 MIRc = $40!!! Has 2 x USB 3.0 ports and a good layout too, but rebate is only good until tonight!
Corsair Carbide Series 200R Black Steel structure with molded ABS plastic accent pieces ATX Mid Tower Computer Case
January 28, 2013 2:11:52 PM
Thanks guys, could have sworn I checked the socket type... but that's what this forum is for I guess haha. Alright so I'll switch to a different mobo that actually supports the CPU. As far as gaming performance, how will this build do?
(Also, gussrtk my budget is ~$550 for parts and I'm located in California)
m
l
January 29, 2013 1:19:32 AM
You could use my AMD build above for $570 or drop the GPU down to a 7850 and save about $30, which would bring the build down to ~$540.
$170 shipped!
HIS H785F1G2M Radeon HD 7850 1GB 256-bit GDDR5 PCI Express 3.0 x16 HDCP Ready CrossFireX Support Video Card
But to be honest, if you can afford the $570 price tag with the 7870, I would do it. Otherwise go with the 7850 to keep you within your budget.
m
l
February 3, 2013 2:42:07 AM
Yea, I think I'm gonna bite the bullet and go with the 7870, seems like it'll be worth it in the long run, thanks guys!
m
l
February 3, 2013 2:42:17 AM
Best answer selected by yoshiji.
m
l
