Hi, I recently purchased an msi tf3 7950 from newegg. This is my very first graphics card for my very first build and its great except only one problem it gets hot. I am debating weather to rma to newegg or return to msi depending on the feedback from you all.
These numbers are with stock volts of 1031mv and stock clocks 880mhz and 1250 on the memory, all manual fan settings. Idle has always been 32c sometimes 28c in the morning.
Originally gaming temps during BF3 multiplayer, on ultra @1280x1024, at 65% fan were 78c to 80c sometimes reaching 83c. Bitcoin mining required the fan to be at 85% or more for temps to stay around 85c. So I looked online, apparently msi does some bad TIM applications, well it gets worse then that upon opening my card I found 3 little globs of solder on the heat sink as if it had splashed onto it. TIM application looked fine compared to the mess I have seen on some. Upon further investigation there is more of these tiny solder balls on the heat pipes and fins. I used a scalpel to remove the solder balls on the gpu contact plate, which exposed some copper underneath around the edges of the HS.
Reassembled with AS5 here are my temps after a week or so of doing this.
House temp between 65f and 68f room is probably a little warmer around 72f not sure.
Case is opened up Fractal Arc Midi
Idle 28c to 32c 65% fan
BF3 metro 64p 72c at 65% 96c after 7 minutes at 50% fan had to stop
BitCoin Mining 79c at 65% no need to try 50% here as the above will give you a good idea
Furmark 78c 65% 1024x576 8x MSAA for 5 minutes
I also have coil whine but I'm more worried about these temps.
How bad are these temps? Will newegg accept an rma for this, should I go through msi, or am I screwed since I scratched the nickle coating on the HS where it comes in contact with gpu. Ive had good luck with every part of my build except for this and am unsure what to do. Thanks in advance for your input.
