Help for first built
Hi, I'm beginning my first build and it's kind of a budget build so it around 500 - 550. I've found these parts and am wondering wether or not they will function well together. (I don't want to waste time sending them back to newegg.) The primary purpose of the build is for gaming.
APEVIA X-JUPITER-JR G-Type X-JPJGT-BK Black SECC Steel ATX Mid Tower Computer Case
ASRock FM2A75M-DGS FM2 AMD A75 (Hudson D3) SATA 6Gb/s USB 3.0 Micro ATX AMD Motherboard
HIS IceQ H787Q2G2M Radeon HD 7870 GHz Edition 2GB 256-bit GDDR5 PCI Express 3.0 x16 HDCP Ready CrossFireX Support Video Card
CORSAIR Builder Series CX500 500W ATX12V v2.3 80 PLUS BRONZE Certified Active PFC Power Supply
G.SKILL Ripjaws Series 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL9D-4GBRL
AMD Phenom II X4 965 Black Edition Deneb 3.4GHz Socket AM3 125W Quad-Core Processor HDZ965FBGMBOX
4 answers Last reply
More about help built
  1. OP here, I'm using a mechanical hardrive from my past pc so i dont have to buy windows and it has lots of storage left. Also scavenging the optical drive.
  2. This topic has been moved from the section CPU & Components to section Systems by Mousemonkey
  3. Apevia cases are horrendous and very poorly made. Stay away from them. Also that motherboard won't work with that CPU. You will need either the A10-5800K or go with an AMD 970 board.
  4. If you change the motherboard you will need to do a fresh install of windows 7 on the harddrive.
Build Systems
