Solved
Bitcoin Mining help?
  • Radeon
  • Graphics
December 14, 2012 12:24:59 AM
I have a Sapphire HD Radeon 7850 (Oced to 1050 on core, 1300 on mem) and when I start up bitcoin it shows 360mh/s, but gets stuck at 300 mh/s. Am I doing something wrong here? I have made like, 0.24 bitcoin using slushs pool in the last two weeks. Any help would be appreciated.
More about : bitcoin mining
December 14, 2012 12:37:11 AM
Yes, you are doing something wrong. Its called "bitcoin mining". Its a fantastic way to raise your electric bill though
m
l
December 14, 2012 12:38:34 AM
Hate all you want on it, im not doing it spesifically for the money, although it is a bonus.
Just tell me if there is something wrong with my mhashs and BTC rate, or if you can't don't answer.
m
l
Best solution
May 1, 2013 11:45:52 AM
I know this is an older thread but without increasing voltage you should be able to pull around 315MHash/s with increasing voltage you should get alot higher and closer to 400MHash/s. You can see an example config file that pulls 315MHash/s running at around 45 degrees - http://cur.lv/u0rc ... If you use that example and play with voltage you should be able to get about 25% more MHash from your 7850.
June 9, 2013 5:36:02 PM
Thanks for actually answering my question. So this rate is normal for a 7850 huh? Sweet I guess.
m
l
