Archived from groups: microsoft.public.windowsxp.games (More info?)
When i play games, i insert the CD into the CD drive, then the game starts
up. But after the brief loading screen, the computer automatically reboots
itself-it has a blue screen with some writing, but this disappears too
quickly for me to read it, and the pc restarts.
Can someone please help, this problem has only developed recently, before i
had no issues with this.
Sponsored Links
The first things I would do is make sure you have enough memory to run the
games. If you do my next step would be to run a virus scan, and an adware
scan. Ad-aware se and/or sprbot are both free and very good. You might also
want to run the video diagnostic and update you driver
Reply to Anonymous
Hi Rob,
"Rob" <Rob@discussions.microsoft.com> wrote in message news:93AAFE87-1EB1-4381-AAAB-02260F0FCA6A@microsoft.com...
Your system is set to restart automatically after STOP events.
To stop this behavior go to Control Panel / System / Advanced /
Click the Startup and Recovery Settings button / Uncheck the box
labelled "Automatically restart" under the System Failure section.
To analyze the error, try the steps in: http://aumha.org/win5/kbestop.htm
If the error indicates a file name that begins with ati, or nv (nVidia)
the most likely solution would be to install the latest drivers using
the instructions at: http://mvps.org/nibblesnbits/Video.html#drivers
Cheers, Windows XP MVP Shell / User
Jimmy S. http://mvp.support.microsoft.com
Game FAQs: http://support.microsoft.com/default.aspx?scid=FH;[LN];gms
Visit my Zone.com / Gaming Helpsite: http://nibblesnbits.tk or Call / Contact
MS Support at: http://support.microsoft.com/defau [...] ;en-us;top
My advice is donated "AS IS" without warranty; nor do I confer any rights.
_________________________________________________________
Reply to Anonymous
I analysed the error, it says my cdrom has a bad block.
What does this mean, and is there anyway to fix it?
What is more strange is that i can play a few games, but most don't work.
"Jimmy S." wrote:
> Hi Rob,
Reply to Rob
Hi Rob,
You might just need to clean your CD ROM and CD's.
They have kits available for that at most tech shops now. :-)
Visit my MSN Zone.com and Gaming Help Site: http://mvps.org/nibblesnbits
MS Assisted Support: http://support.microsoft.com/select/?target=assistance
"Rob" <Rob@discussions.microsoft.com> wrote in message news:6C9F0E27-DF57-4B93-B2AB-6DBD03AF912F@microsoft.com...
> "Jimmy S." wrote:
>> Hi Rob,
Reply to Anonymous
Hi Jimmy,
Thanks for your help so far, but the problem still isn't fixed.
Here's the message i get when i get the STOP error:
***STOP: 0x0000008E (0xC0000005, 0x000001EE, 0xEF984CC8, 0x00000000)
I have updated my drivers and the problem still exists.
The final piece of advice it gives me is to alter my BIOS memory options,
e.g caching/ shadowing. Any idea what this means?
When it says i have an error with my cd rom (a bad block), why does this
only affect certain games and not others?
Thanks,
Rob
"Jimmy S." wrote:
> Hi Rob,
> > "Jimmy S." wrote:
> >> Hi Rob,
Reply to Rob
Same CD-Rom drive or on anothr unit?? It may be that the CDs the cause the
problem have used more disc space and the C-Rom drive is "flaky" from that
position on. Have you tried the game on a different PC or CD-Rom drive??
news:B099342E-6A9C-442B-ADD9-0AD6B67F1ECF@microsoft.com...
> Hi Jimmy,
> Thanks,
> Rob
> "Jimmy S." wrote:
>> Hi Rob,
>> rights.
>> > work.
>> > "Jimmy S." wrote:
>> >> Hi Rob,
>> >> > starts
>> >> > reboots
>> >> > too
>> >> > before i
>> >> (nVidia)
>> >> Jimmy S.
>> >> Contact
>> >> MS Support at:
>> >> rights.
Reply to Anonymous
Hi Rob,
What method did you use to clean your CD ROM/CD's?
"Rob" <Rob@discussions.microsoft.com> wrote in message news:B099342E-6A9C-442B-ADD9-0AD6B67F1ECF@microsoft.com...
> Hi Jimmy,
> Thanks,
> Rob
> "Jimmy S." wrote:
>> Hi Rob,
>> > "Jimmy S." wrote:
>> >> Hi Rob,
Reply to Anonymous
Tom's Hardware > Forum > Windows XP > Windows XP General Discussion > Problem with CDs
There are 588 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
