Solved
Decision Help
Hi, After some very extensive research I have came to a decision about which GPU I am going to get my problem is that I am crossed between these two I need help from some one more knowledgeable than me about GPU's to help me decide I plan on running on 1920x1200 maybe dual screens one day and I plan on heavily modding skyrim. I also will be keeping this card for a while because I will not be upgrading that often so I want one set for the next while this will be my first computer build so much help would me appreciated thanks. For you to understand why I am stressing over this is because I am upgrading from a Radeon HD 2400 (I know). Thanks again
http://www.newegg.com/Product/Product.aspx?Item=N82E16814125448
http://www.newegg.com/Product/Product.aspx?Item=N82E16814121634
4 answers Last reply Best Answer
More about decision help
  1. As you said you'll upgrade to 2 screens one day, you'll probably need the Gigabyte one.
    Because 1080p+ resolutions use more than 2GB of VRAM. And the Gigabyte one is very cool.
  2. What about just one screen
  3. Best answer
    They both will be fairly same. Asus is one of the leading brand.
    Now the choice is yours.
    I would get the Gigabyte one because it will future proof. You can easily upgrade to 2 monitors and still get the best. Or else is any game in future may require more than 2GB.
    Search some more Cards. More brands and check Benchmarks.
  4. Best answer selected by preet3203.
Graphics Cards GPUs Graphics Product
