Closed Solved
First time building, motherboard will not display a signal or POST.
Please assist me in any possible way. This is my third week working on my first custom gaming pc build. Parts are as follows
1 x G.SKILL Ripjaws Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL9D-
1 x ASUS P8B75-V LGA 1155 Intel B75 SATA 6Gb/s USB 3.0 ATX Intel Motherboard
1 x Antec Three Hundred Illusion Black Steel ATX Mid Tower Computer Case
1 x SAPPHIRE 100358L Radeon HD 7770 GHz Edition 1GB 128-bit GDDR5 PCI Express 3.0 x16 CrossFireX Support Video Card
1 x LOGISYS Computer PS575XBK 575W ATX12V SLI Ready Power Supply
1 x Intel Core i3-2120 Sandy Bridge 3.3GHz LGA 1155 65W Dual-Core Desktop Processor Intel HD Graphics 2000 BX80623I32120
1 x SAMSUNG Spinpoint F3 ST1000DM005/HD103SJ 1TB 7200 RPM SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive
1 x SAMSUNG DVD Burner SATA Model SH-224BB - OEM
1 x Microsoft Windows 8 64-bit (Full Version) - OEM
1 x Rosewill RNX-N300X PCI Wireless Adapter
My motherboard will not post. I made the mistake of not purchasing a motherboard speaker so I cannot hear any beeps. I have tried an out of box setup (breadboarding?) with just one stick of ram and the cpu with the 24 pin and the 8 pin power plugs. I get no signal/POST. When I have it in the case on the standoff pins with everything plugged in, the fans all run but I still get no post. I contacted newegg when this first happened and was informed I had a bad motherboard. So I RMA'd it and purchased a new one. Same problem. So then I contacted the manufacturer of my current motherboard, ASUS and I am told that it is definately my ram. Still doesnt work. What should I do?
9 answers Last reply Best Answer
More about first time building motherboard display signal post
  1. So you have replaced the ram?
  2. Yes I replaced my oginal corsair pair with the G-skill listed above. It was a prdouct that the motherboard listed as a qualified vendor. I also tried resetting the CMOS battery
  3. Best answer
    Not your exact model, but I'd be suspect of that no-name PSU:
    http://www.hardwaresecrets.com/article/Logisys-PS600A12-Power-Supply-Review/1211/7
    That would be my next component to replace.
  4. Quote:
    eeeek....
    http://www.hardwaresecrets.com/art [...] iew/1211/7
    ^^ this.
  5. Agreed that your PSU doesn't look great. Get a cheap cosair/antec unit
  6. Thank you for the helpful responses! I have RMA'd my processor, and I plan on purchasing a new power supply based on your feedback. Would you be able to suggest a good power supply? Would either of these be good?
    http://www.newegg.com/Product/Product.aspx?Item=N82E16817152041&Tpk=raidmax%20rx-600AF
    http://www.newegg.com/Product/Product.aspx?Item=N82E16817152028
  7. Best answer selected by brennanman007.
  8. The best is that corsair unit. I wouldn't trust raidmax PSU's.
New Build Systems Product
