Hello,
I recently purchased some SilverStone silent foam sound dampening material, and was looking to apply it to my htpc. My question is short and sweet;
Is it safe to apply this directly to the bottom of the case, directly under the mobo? With holes for the mounting screws of course.
I ask in case there are any possible side effects that can come from the underside of the mobo touching the foam (be it static, heat, etc.) My goal is to have every metal surface inside the case covered.
Thank you!
Thank you!
