Closed Solved
Crysis 3 Online build, Please Help!
Hi guys,
So I’m not much of a Crysis enthusiast, so I thought I would ask you lads:
Crysis 3 multiplayer is due out next month and I want to be running it on medium/high graphics, my current build is:
I5 – 2500k series CPU
1 Radeon 6970 Factory OC (BF3 Edition GPU)
Coolmaster 750W Bronze PSU
Darkfleet full tower gaming case,
2 - 10k RPM V-Raptor Hdd’s (Not in a raid)
12GB DDR3 @ 1600
AS Rock Z77 Extreme 9 Mobo
What can I do to get up into that medium/high graphics settings in Crysis 3 with reasonable frames..? Hit me with all options, Overclocking, Crossfire, Complete new build, new CPU, Budget is about 500-600.
I will give a best answer.
Thanks,
5 answers Last reply Best Answer
More about crysis online build help
  1. Best answer
    Go download the demo that's out and test. It's a rather lightweight game and the demo has 2 different modes for 16 player multiplayer.
    For reference, I'm getting 60FPS on medium, 1280x1024, 7750 $70 graphics card, 4 year old AMD Phenom 1090T. High, I can get 30-40FPS. You card is way better than mine.
  2. ^^^ on low eye candy.
    your card will play it fine on 1080p, just no eye candy like AA. dont need it much anyways. get the demo and test.
    Ya, even low-high on the game doesn't seem to make much of a difference. If it runs decent, I wouldn't spend $500 to upgrade to play 1 game, that I don't even really like. lol.
    Download the demo, try it out, see if you're happy with your systems performance.
  4. yeah ok good call,
    Shal do, thanks for the comparison geto
    What is AA?
  5. Best answer selected by Combat Wombat.
Build Crysis Systems
