Hello everyone, I am a college student who is trying to build credit to get a chevy camaro 2013 I have about 4 grand on a secured card but i only wish to spend anywhere from 2-2.5 grand on the system so i can pay it off quickly.
http://www.newegg.com/Product/Product.aspx?Item=N82E16811146073 -- 120 - CASE - NZXT Phantom PHAN-002OR
http://www.xoxide.com/xsp-craystorm750rs240watercoolingkit.html -- 143 - WC - XSP Craystorm 750 rs240
http://www.newegg.com/Product/Product.aspx?Item=N82E16819116504 -- 230 - CPU - i5 3570K
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130824 -- 440 - GPU - GTX 670 4GB
http://www.newegg.com/Product/Product.aspx?Item=N82E16813157293 -- 135 - MOBO - MauveCloud recommended asrock extreme 4 z77
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231429 -- 100 - RAM - G.Skill Ripjaw
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139011 -- 160 - PSU - 850w Gold Cert
http://www.newegg.com/Product/Product.aspx?Item=N82E16820227813 -- 170 - SSD - 240GB
http://www.newegg.com/Product/Product.aspx?Item=N82E16822148840 -- 80 - HD - 1TB 7200 rpm
----- GPU WATERBLOCK -----
http://www.frozencpu.com/products/16701/ex-blc-1190/XSPC_Razor_nVidia_GTX_670_Full_Coverage_VGA_Block_-_Reference_Design.html?tl=g30c311s1708#blank
- 105
Before Tax / Shipping: 1683
I'm probably going to change the RAM out with the black colored same version of it so that it looks better in the case. Also, this is my first water cooling build so please input. I read the thread on how to waterloop and how to set it up and the basics in the main thread but I've looked at several coolants. I also understand that most games don't need Hyperthreading so i just took an i5 3570k instead of a i7 3770k. My reasoning for picking the GTX 670 4GB is because I'm more then likely going to use 2 -3 monitors and the extra 2GB of vid memory I've read helps out with multiple screens so the GTX 680 2GB is out of the question. Another big plus is I chose the Saber Tooth mobo because it has shielding which could save me if a leak sprung in the water cooling build.
Please tweak, and give me constructive criticism I've gone through so many different build ideas its not funny.
ALSO: Cougar 120mm fans or Scythe fans? And when i mount the radiator I'm wanting to remove that bottom left hard drive cage in the case and place it between the front and the PSU and mount a fan on the bottom to bring in cool air then fans ontop to push the hot air out and change the front fan to shoot the air out to expel the hot air quickly from the radiator.
- 105
