Nvidia control panel only showing 3d vision setting
i update my gpu driver with latest driver 306.97
then i opened my nvidia control panel. it showing "stereoscopic 3d" option only. no other option there.
whats the problem with this..help me
GPU : nvidia geforce 210
3 answers Last reply
More about nvidia control panel showing vision setting
  1. Uninstall your drivers, and try installing them again. You might want to download the latest version again. You may have not grabbed the right download.
  2. how to uninstall
    by "uninstall or change a program" from control panel
    is am right?
  3. I usually uninstall all NvIDIA related stuff in add or remove programs (Uninstall or change a program if your not old school lol) and then delete the Nvidia folder in my OS drive. Then select clean install on the .exe for the driver
Nvidia Control Panel GPUs 3D Graphics
