My monitor wont turn on.
I just got a new Gigabyte 660 GTX OC. I have it plugged into my psu and my mobo, but when I plug it into my desktop my screen does not turn on. I have no dvi cables, but I used a vga-dvi cable to plug it into my monitor. I can use my computer normally if I plug my monitor into my mobo for using the integrated graphics chip. The GPU seems to be working as the fans are spinning, but It doesn't come up as registered hardware on my computer.
More about : monitor wont turn
Related ressources
Graphics card Master
Monitor Authority
Could you list all the connectors you have connected to somewhere from your power supply unit? It could be great if you do that list while checking all of them if they are firmly connected, rather than from your mind.
Okay this is from looking don't worry.
I have one 6+2 PCI-E slot filled and 3 Sata/peripheral slots filled.
The GTX 660 is connected in the PCI-E slot. They are all firmly in.
I wouldn't think that it is a problem with my PSU as the fans are working. Also the GPU is not detected in my BIOS or in my device manager.
Monitor Authority
Looks connected fine. GTX 660 only needs only connector. Are you positive that cable of yours works in other situations? If so, do you have somebody in whose PC you could try the card to see whether it's not dead?
Graphics card Authority
Hi - you may have to go into BIOS & disable the integrated graphics and
enable the PCI-E graphics. You also might have to clean(remove) the
integrated grpahics drivers, then install the discrete GPU's drivers,
preferably from the makers website and not from the dvd
that came with the vid card.
Tom
Monitor Authority
That won't work. It's been a few years since motherboards automatically change between integrated and PCIe graphics, and there will definitely be no option to change this in the BIOS. Furthermore, drivers aren't used until booting to windows, and he cannot even see BIOS screen, so that will not help either.
Actually that's exactly what I did with my BIOS 2 month's ago when I got my
new GPU(hd7870), and it is a relatively new MOBO (Gig z77-3dh)
and it worked perfectly.
Sunius said:
I really doubt you specifically DISABLED integrated graphics in BIOS. There's no such option.
And of course you got it working, but even if you didn't do that, it would have worked.
Believe whatever you want, there is such an option(I just went back in and confirmed)
in the peripherals section of my 2011 BIOS for integrated graphics and it is disabled
(which I did 2 months ago), and if you care to research AMI's BIOS
from 2011 you can confirm such an option exists, instead
of running your mouth without checking the facts.
