Will a corsair hx 550 be enough to power a 690?
Will a corsair hx 550 be enough to power a 690?Or will I need an upgrade if that's the case then I will get an hx 850
8 answers Last reply
More about will corsair power
  1. I suspect you will need a more powerful PSU but to find out put your specs into this: http://extreme.outervision.com/psucalculatorlite.jsp
  2. It should be able to run it depending on what CPU and other components it has to power but you'd be cutting it close. Also you wouldn't be able to overclock the card or the CPU. What is the exact model you have? They don't make a HX series that's 550 watts. Please also list what you have and if it's at stock settings.
    Check out your power use here, it's the most accurate calculator I've found.
    http://www.extreme.outervision.com/psucalculatorlite.jsp
    http://www.extreme.outervision.com/PSUEngine
    For what I have right now you can just click on the banner in my sig and I meant tx not hx for the 550http://www.newegg.ca/Product/Product.aspx?Item=N82E16817139032
  4. But with that you're easily within your PSU's limit. I'm talking about the HDD (7200 RPM?) and/or SSD, optical drive, SSD, even how many fans the case has and what size. Six high performance fans can be the extra 40-60 watts that sets the PSU over.
    Now if you don't have many accessories you should be fine.
    I have one seagate barracuda 500gb @7200 rpm and 3 low rpm 230 mm case fans one normal 140 mm and one 120 mm for the CPU and a touch screen fan controller from nzxt
    last on the list is a generic cd reader writer
  6. Then you should be fine.
    I suggest you buy a cooler master gx 750 watts or gx 650 watts (both are 80 plus bronze certified)
    I think it will suit your needs
    http://www.coolermaster-usa.com/product.php?product_id=2974&product_name=GX%20750W
    click the link above for cooler master gx 750 watts.
    http://www.coolermaster-usa.com/product.php?product_id=2973&product_name=GX%20650W
    click the link above for cooler master gx 650 watts.
    you can select Silent Pro Hybrid 850 Watts instead of hx 850 because Silent Pro Hybrid 850 watts has Nvidia SLI ready support
    http://www.coolermaster-usa.com/product.php?product_id=3057&product_name=Silent%20Pro%20Hybrid%20850W
    click the link above for cooler master Silent Pro Hybrid 850 watts.
    Just 2 be safe you know!!!
  8. But why spend the money when he doesn't have to. Also you'll learn never to recommend a CM PSU their awful and you should never get one.
Nvidia Cases Corsair Power Graphics
