hi, im having this really though issue of FPS drops for one second at a time every couple of minutes.
i tried everything even opened up a thread here : http://www.tomshardware.com/forum/382613-33-tomshardware
in an effort to test i entered a game and monitored the GPU stats in-game. what i found out was that when i get this lag
the only thing that changes is the TDP of the GPU which goes from 98% to 37% than back up.
everything else is the same even the gpu clocks.
like i mentioned in the previous thread, it's also happening in minimum graphics settings.
tha'ts led me to beleive that maybe it's a PSU prbolem.
my specs are:
i5 3470
GigaBYTE gtx 660
b75-d3h
1 tb seagate hdd
430w seasonic PSU.
i have only 2 fans, nothing special and on top loads my system is needs to take no more than 300W.
ive checked almost everything from drivers to TEMP. do you think it could be that the PSU is choking my GPU?
vefore i purchased the system they clarified that as long as i don't overload my system with ssd's,SLI,OC , i should be fine and
that this PSU is more than ebough.
UPDATE: it's not just the TDP. when the lag occurs the GPU core load and Memory load drops to 0 for a split second.
i really need your help it's driving me crazy...
thank you
my specs are:
i5 3470
GigaBYTE gtx 660
b75-d3h
1 tb seagate hdd
430w seasonic PSU.
thank you
