Budget Range: $1500 Max (including shipping & Handling, tax)
System Usage from Most to Least Important: Gaming, web surfing, general use
Are you buying a monitor: No
Do you need to buy OS: Yes
Preferred Website(s) for Parts: Newegg.com, tigerdirect.com, amazon.com - US only
Parts Preferences: AMD and/or Intel
Overclocking:No
SLI or Crossfire: Maybe
Your Monitor Resolution: 1920x1080, 23” monitor
Additional Comments: Looking to run Battlefield 3 on high with 60+ fps in hot zones ( atleast not dip below 32 fps). I'd like to stick with a decent price/performance ratio. SSD that can hold windows 7 and battlefield 3, so it's gotta be a good size one. Already own a 1.5TB HDD, monitor, KB/M. No water cooling please, good airflow ( possibly with the option to add more fans later if need be).
If you can build a rig that will run BF3 on High with 60+ fps for under the budget. ( say $500 less, please do so, because then I can save what's left for upgrades or extras in the future.)
You don't have to tap out the budget, I will be using pcpartpicker my self with different style builds but would like some help from people that have built custom rigs before and know the best price/performance ratio.
If there is any thing else you need to know just let me know.
~jjg2013
Overclocking:No
~jjg2013
