Will my parts work together?
Hey guys I was wondering if all of my parts are compatible with each other.
http://pcpartpicker.com/user/nic714mar/saved/#savedbuild_266078
6 answers Last reply
More about will parts work together
  1. Use the website here (http://pcpartpicker.com/) and select Get Started. Once you have selected all of your components, use the BBCode Markup button in the top right. Copy and paste the list in your post, here at Tom's. This makes it much easier for use to view.
    Will do
    Alright I did that
  4. If this rig will primarily be used for gaming, you can save a lot of cash. Your suggested build is quite the bit overkill.
    Overclocking and future SLI:
    CPU: Intel Core i5-3570K 3.4GHz Quad-Core Processor ($223.79 @ Amazon)
    CPU Cooler: Phanteks PH-TC14PE 78.1 CFM CPU Cooler ($79.99 @ Newegg)
    Motherboard: MSI Z77A-GD55 ATX LGA1155 Motherboard ($124.99 @ Amazon)
    Memory: Crucial Ballistix sport 8GB (2 x 4GB) DDR3-1600 Memory ($43.98 @ Outlet PC)
    Storage: Seagate Barracuda 3TB 3.5" 7200RPM Internal Hard Drive ($137.98 @ SuperBiiz)
    Storage: OCZ Vertex 4 256GB 2.5" Solid State Disk ($212.95 @ Mac Connection)
    Video Card: EVGA GeForce GTX 670 2GB Video Card ($383.98 @ Newegg)
    Case: Cooler Master HAF 932 Advanced ATX Full Tower Case ($119.99 @ Newegg)
    Power Supply: SeaSonic M12II 750W 80 PLUS Bronze Certified ATX12V / EPS12V Power Supply ($115.17 @ Newegg)
    Optical Drive: Asus BW-14D1XT Blu-Ray/DVD/CD Writer ($99.99 @ Amazon)
    Total: $1542.81
    (Generated by PCPartPicker 2013-02-02 13:50 EST-0500)
    The i7 is useless for gaming because games do not utilize hyperthreading. Not sure if you intend to overclock but I included the option. Same with future SLI. If you are not going to be doing either of those things, you can save more cash. 1000W is way overkill for PSU. 750W is fine even for SLI. You can also save on the Blu-Ray player unless you are really serious about playing Blu-Ray discs on the rig. The 680 is way overpriced as the 670 has just a slightly lower performance value. 16GB RAM is overkill for gaming as well.
    Not overclocking or SLI (with personal preferences):
    CPU: Intel Core i5-3570 3.4GHz Quad-Core Processor ($199.99 @ Amazon)
    Motherboard: ASRock H77M Micro ATX LGA1155 Motherboard ($69.99 @ Newegg)
    Storage: Samsung 830 Series 128GB 2.5" Solid State Disk ($109.99 @ Newegg)
    Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive ($69.98 @ Outlet PC)
    Case: Rosewill THOR V2 ATX Full Tower Case ($115.88 @ Amazon)
    Power Supply: SeaSonic G 550W 80 PLUS Gold Certified ATX12V / EPS12V Power Supply ($89.99 @ Newegg)
    Optical Drive: Lite-On iHAS124-04 DVD/CD Writer ($16.98 @ Outlet PC)
    Total: $1100.76
    (Generated by PCPartPicker 2013-02-02 13:59 EST-0500)
    Total: $1542.81
    Total: $1100.76
    Are the parts compatible together is what I asked. The reason I am getting an i7 and 16GB of ram is because I edit.
  6. Sure. It will work. Is it overkill, even for editing? Yes. Would you like some suggestions on bringing the cost down?
Homebuilt Compatibility Systems Product
