My first build!! HELP!
http://pcpartpicker.com/p/B8h4
Is this a good rig?
I wanna play BF3 on Medium Settings with 20-30 FPS.
3 answers Last reply
More about build help
  1. 20-30 fps will be very choppy I recommend you get a radeon 7770 for $10 more. You will actually get 40 fps on high details with this card or over 50 fps on medium
    http://www.newegg.com/Product/Product.aspx?Item=N82E16814202011
    Also get a better psu, its brand is sparkle because it will literally catch on fire! (j/k)
    Get this instead its $30 cheaper and better:
    http://www.newegg.com/Product/Product.aspx?Item=N82E16817139026
    Also found a cheaper dvd writer for you. Do you have a problem with newegg or something? None of your parts are from there.
    http://www.newegg.com/Product/Product.aspx?Item=N82E16827136259
    It cost 50$ more CAD. Any other suggestions for videocards?
  3. Hi. Don't get that PSU and get the one below instead. The GTX 650 Ti is a good choice. Feel free to make changes as you'd like.
    CPU: AMD FX-6100 3.3GHz 6-Core Processor ($113.54 @ DirectCanada)
    Motherboard: Asus M5A78L-M LX PLUS Micro ATX AM3+ Motherboard ($54.03 @ DirectCanada)
    Memory: Crucial Ballistix sport 8GB (2 x 4GB) DDR3-1600 Memory ($42.85 @ DirectCanada)
    Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive ($67.99 @ NCIX)
    Video Card: Zotac GeForce GTX 650 Ti 1GB Video Card ($124.99 @ Canada Computers)
    Case: Zalman Z9 Plus ATX Mid Tower Case ($34.99 @ NCIX)
    Power Supply: XFX ProSeries 450W 80 PLUS Bronze Certified ATX12V / EPS12V Power Supply ($50.71 @ DirectCanada)
    Optical Drive: Asus DRW-24B1ST/BLK/B/AS DVD/CD Writer ($19.99 @ Canada Computers)
    Total: $509.09
    (Generated by PCPartPicker 2013-02-02 23:26 EST-0500)
    Here's a building guide with videos: http://techreport.com/review/23624/how-to-build-a-pc-the-tech-report-guide
Prebuilt Battlefield Build FPS Systems Product
