DVL-919E power problem
Forum Home Cinema Equipment : Laser Disc Players - DVL-919E power problem
Archived from groups: alt.video.laserdisc (More info?)
My Pioneer DVL-919E appears to have suddently given up the ghost. I
powered it down a week ago and it now refuses to power up. The unit
appears totally dead; the are absolutely no sounds when connecting a
power cable or pressing the power button.
I have checked a couple of things, namely trying a different power
cable and checking the (3.15A) fuse just inside case, but neither has
resolved the issue. I'd welcome any recommendations on what else I
should look at.
Thanks in advance.
Sponsored Links
If the fuse in the power supply is blown then you need to cut out the
ARC/Surge Suppressor which is a cheap one and can short out in error. In
the DVL-909 it is D105 in the power supply board. The DVL-919 probably has
the same Power Supply but I don't have the service manual to compare.
This is a common failure in the DVL and some LD players.
Kurtis
"Richard Forster" <syllepsis@gmail.com> wrote in message
news:aaf5e89d.0504100613.292cb2b@posting.google.com...
> should look at.
> Thanks in advance.
Reply to Anonymous
Beware that the DVL-919E is the European version which has a 100V-260V input
voltage power supply. This differs from the US version which is 120V. Power
supply of the DVL-919E is the same as the European DVL-909 models. If you
need a schematic diagram, I can provide one for you.
The DVL-919E has the same appearance as the champagne colored DVL-909 did,
whereas the American DVL-919 had a different front panel and is black.
Regards,
Nico de Vries
"Kurtis Bahr" <kbahr@comcast.net> wrote in message
news:FNSdnTGjoNgpAMTfRVn-pg@comcast.com...
has
> Kurtis
> > should look at.
> > Thanks in advance.
Reply to Anonymous
On Fri, 22 Apr 2005 21:26:28 +0200, Nico de Vries <nicodev@freeler.nl> wrote:
How is that a problem? Will it not run on 60hz 120V?
>Regards,
Reply to Anonymous
The "E" version usually have a little different layout on the primary side
of the supply where this part verses the North American version I mentioned.
For that reason I cannot tell you what the suppression diode is labeled as
in your unit. A schematic from Nico would be the best option to verify
where this part is in the European version.
Kurtis
"TCS" <The-Central-Scrutinizer@p.o.b.o.x.com> wrote in message
news:slrnd6ipu5.lkm.The-Central-Scrutinizer@linux.client.comcast.net...
>>input
>>Power
>>Regards,
Reply to Anonymous
The DVL-919E will run on 120V 60 Hz, as it accepts any input voltage between
100 and 260 Volts. My point was to avoid confusion between the US DVL-919
power supply and the DVL-919E one, as they fundamentally diffrent on the
primary side.
Regards,
Nico de Vries
input
Power
did,
> >Regards,
Reply to Anonymous
Thanks for helping with the 919E version power supply. Since I do not have
a manual I was not aware it did not have the Arc Suppressor. This is why
the newsgroup is good, we can all help each other.
Kurtis
"Nico de Vries" <nicodev@freeler.nl> wrote in message
news:27381$426a6d0e$3e15b62e$14929@freeler.nl...
> between
> primary side.
> Regards,
> Nico de Vries
> input
> Power
>> >you
> did,
>> >Regards,
Reply to Anonymous
Tom's Hardware > Forum > Home Cinema Equipment > Laser Disc Players > DVL-919E power problem
There are 1173 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
