HELP!!! Radeon hd 7950 problem with video card Driver
When I download the driver from amd for my radeon hd 7950 it causes a bunch of spots to appear randomly on the screen, but when I uninstall it the spots disappear. Here are some pictures of the spots.
http://gyazo.com/413a6c6dea10a9a17b5b7a081105e9f9
http://gyazo.com/065583bb71e6b273ffa6a6fc6670ed9e
http://gyazo.com/f8eb1dc66e43f4ef9dca800931b2b2a9
I have no idea how to fix this, I figured I was driving the wrong driver which i put for
step 1: desktop graphics
step 2: Radeon HD series
step 3: Radeon HD 7xxx series Pcle
step 4: windows 7 64 bit
I dled Catalyst Software Suite with .NET 4 Support and Latest Beta Driver with .NET 4.0 Support, but same problem occurs. I don't know am I downloading the wrong thing or something? Can you guys please help me?
6 answers Last reply
More about help radeon 7950 problem video card driver
  1. I have also tried putting in my sapphire radeon hd 7950 again into the motherboard, but still same problem. It stops only when I uninstall the AMD driver.
  2. try a fresh re install of windows then see if you get the same problems.
  3. try using Driver Sweeper before you do a fresh install of windows. might save you a bunch of trouble.
    http://www.guru3d.com/content_page/guru3d_driver_sweeper.html
  4. So i did a fresh re install of windows, dled the driver again and when i dled it the samw rhing happens. Im getting frustrated. Could it be the software, monitor? I have no idea honestly. Any help would be greatly appreciated
  5. So I called AMD and told them about my situation. They suggested that my graphic cards may be busted and get a replacement. I think it could be cause when I play CS GO there are sometimes when the dots disappear but usually they reappear. Ill keep you guys updated and see how it works out
  6. I got my video card put it in and installed the driver. I checked my dxdiag and it showed this
    http://gyazo.com/01bcb01c614d14142657e87133347f9c
    http://gyazo.com/35273f7a6cd987c0ee4c59f21e72ec33
    when I run counter strike global offensive I check the fps rate and it is the same as my integrated graphics. I checked my video card on device manager and it says its running properly
    http://gyazo.com/dda2a344e54298bc267614f81554e1c7
    I try to play far cry 3 and its the same when i had my integrated graphics. Any help is appreciated
Radeon Graphics Cards HD Graphics
