hey guys,
Budget Range: as title says $1200 (bit of give if needed in both directions)
System Usage from Most to Least Important: Gaming - Fps / MMO > Movies > Surfing web
Are you buying a monitor: no.
Parts to Upgrade: I'll be providing link to my build.
Do you need to buy OS: Yes. Still on vista from a system I bought in 2007. I would like to try win7 or 8 which ever you guys think.
Preferred Website & Location: I'm an Aussie, I think most prices are +10-15% difference from US. Provide websites from anywhere, i'll do the price scanning on the Aus side if needed
Parts Preferences: I was digging the option of using both
Gigabyte GA-990FXA-UD5 Motherboard
AMD FX-8350 8 Core Processor
but found some benchmarks to lead me into an i5 and z77 board - thoughts on this?
This is my build I've been accumulating over the last couple days and is what I would love your opinions on.
New edit:
PCPartPicker part list: http://au.pcpartpicker.com/p/BcBf
Price breakdown by merchant: http://au.pcpartpicker.com/p/BcBf/by_merchant/
Benchmarks: http://au.pcpartpicker.com/p/BcBf/benchmarks/
CPU: Intel Core i5-3570K 3.4GHz Quad-Core Processor ($229.00 @ PCCaseGear)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler ($39.00 @ PCCaseGear)
Motherboard: ASRock Z77 Extreme4 ATX LGA1155 Motherboard ($135.00 @ PCCaseGear)
Memory: G.Skill Ripjaws X Series 8GB (2 x 4GB) DDR3-1600 Memory ($65.00 @ Scorptec)
Storage: Seagate Barracuda 2TB 3.5" 7200RPM Internal Hard Drive ($99.00 @ Scorptec)
Video Card: Gigabyte GeForce GTX 670 2GB Video Card ($419.00 @ PCCaseGear)
Case: NZXT Phantom 410 (Black) ATX Mid Tower Case ($125.00 @ Scorptec)
Power Supply: Antec EarthWatts Green 650W 80 PLUS Bronze Certified ATX12V Power Supply ($89.00 @ PCCaseGear)
Total: $1200.00
Would love to add an ssd but no idea where to start with them.
Thanks in advance !
New edit:
Total: $1200.00
Thanks in advance !
