New build help?
Last response: in Systems
For 900p the 7850 1Gb is good enough
430W is minimal but it is enough for a 7850 and a i3
CPU: Intel Core i3-3220 3.3GHz Dual-Core Processor ($123.79 @ Amazon)
Motherboard: ASRock H77M Micro ATX LGA1155 Motherboard ($69.99 @ Newegg)
Memory: G.Skill Sniper 8GB (2 x 4GB) DDR3-1600 Memory ($43.98 @ Outlet PC)
Storage: Western Digital Caviar Blue 500GB 3.5" 7200RPM Internal Hard Drive ($49.99 @ Amazon)
Video Card: Sapphire Radeon HD 7850 1GB Video Card ($154.99 @ Newegg)
Case: Xigmatek ASGARD PRO (Black) ATX Mid Tower Case ($44.99 @ Newegg)
Power Supply: Corsair Builder 430W 80 PLUS Certified ATX12V Power Supply ($24.99 @ Newegg)
Optical Drive: Asus DRW-24B1ST/BLK/B/AS DVD/CD Writer ($19.99 @ Microcenter)
Operating System: Microsoft Windows 7 Home Premium SP1 (OEM) (64-bit) ($89.98 @ Outlet PC)
Total: $622.69
(Generated by PCPartPicker 2013-02-04 00:21 EST-0500)
For bf3 multi-player and arma2 and AMD build will do better due to good scaling in those games (bf3 64man in particular needs lots of coars :p )
Something like this
CSS is a pretty lax game, pretty much an dual core after core 2 duo/athlon II can handle it
(if you play the 60 man mods though it can be taxing on the cpu)
CPU: AMD FX-6300 3.5GHz 6-Core Processor ($133.79 @ Amazon)
Motherboard: Gigabyte GA-78LMT-USB3 Micro ATX AM3+ Motherboard ($59.99 @ Microcenter)
Total: $622.69
(Generated by PCPartPicker 2013-02-04 00:25 EST-0500)
A good build, I like the budgeting of 2x the cpu price for the graphics card.
Corsair CX430 may be pushing it for a 7850. Yes, it has the required 6 pin power lead, and can deliver 32 12v+ amps. and it is of decent quality.
AMD recommends a 500w psu with one 6 pin pci-e power connector.
It is silent on the 12v amps required. http://www.amd.com/us/products/desktop/graphics/7000/78...
The newer Nvidia offerings tend to use less power. You might consider the GTX660 which is in the same performance tier.
The spec sheet for this unit requires 24a http://www.evga.com/products/pdf/02G-P4-2660.pdf
And... if you live near a microcenter, the i3-3220 cpu can be bought for $99.
