Tom's Hardware > Forum > Computer Peripherals > Printers > usb cable connection
Forum Computer Peripherals : Printers - usb cable connection
wen i download the driver for my printer everything works until it gets to the part about the usb cable connection,i know for a fact i have everything set up right but it says theres no connection..
Sponsored Links
What operating system and printer? It makes a difference. Make sure that your plugged into the USB ports on the PC.
There may also be some problems with USB drivers for the motherboard. Some USB chipsets need a bit of help. Check for solutions at www.usbman.com
Reply to M39shadow
make sure that the printer is turned on before installation.
<font color=red>If your nose <b>RUNS</b>, and feet <b>SMELL</b>.
Then you must be born <b>UPSIDE DOWN</b>.</font color=red>
Reply to jmecor
i don't think, this will be a problem with WINXP, it affects most 9x oses.
Reply to jmecor
If it's a USB 2.0 connection, then you'll need to have installed WinXP SP1 for it to work correctly.
:eek: My CPU runs so hot it creates a quark-gluon plasma :eek:
Reply to WingDing
or an updated USB driver for the mobo.
Reply to jmecor
There are 1302 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
