Archived from groups: microsoft.public.windowsxp.games (More info?)
ok... so I used to open applications that are 16-bit in Windows XP perfectly
fine.... but now I can't it tells me that it's not compatible with the
widows....
http://www.freewebs.com/bandora6/16bit.bmp
Anyways I went to a support page in Microsoft and it said that if that
happens go to Start > Run > then type Command.com........ So I did when I did
that it opened a DOS window but an error came out again... (Which it's not
suppose to
http://www.freewebs.com/bandora6/command.GIF
I closed it... and went back to the support page... it said if an error came
out again go to %SystemRoot%/System32 then find two files... one is
command.nt and Autoexec.nt well I didn't find both... so what shall I do?
NOTE: The game I am trying to install is Freespace 2...
widows....
suppose to
