Need advice on my build
Approximate Purchase Date: Next few weeks
Budget Range: 1400 € (1900$)
System Usage from Most to Least Important: Programming, gaming (High), movies HD, music, everything else
Are you buying a monitor: No
Do you need to buy OS: No
Preferred Website(s) for Parts: Alternate.be (or similar Belgian/Dutch website)
Overclocking: Yes (CPU --> 4.4 GHz propably)
SLI or Crossfire: Maybe at a later stage.
Your Monitor Resolution:1920X1080
Current build:
Mobo: ASUS SABERTOOTH Z77
CPU: Intel® Core™ i5-3570K
CPU Cooler: Noctua NH-D14
GPU: Club 3D Radeon HD 7870XT jokerCard
RAM: Corsair 16 GB DDR3-1600 Quad-kit
HDD SATA600: Seagate ST3000DM001
HDD SSD: Corsair CSSD-F120GBGT-BK (Force GT, difference Force GS)
PSU: be quiet! System Power 7 700W
Optical: LG BH10LS38 (blu-ray)
Case: Cooler Master CM 690 II Advanced
Price: 1363€ or 1846$
The SSD is a Corsair Force GT. The Force GS was available for 20€ less and it seems to have better specs. Should i buy the Force GS?
Any advice on this build would be greatly appreciated.
2 answers Last reply
More about need advice build
  1. Thanks for the responses.
    At first I thought of putting in the nVidia GeForce GTX 670 but for about 150€ less i could get the newer Club 3D Radeon HD 7870XT jokerCard (with the Tahiti LE chipset). It was a big price difference and not a huge difference in performance. But if you guys aren't convinced about the brand 3D then i might go with the GTX 670 and a cheaper MoBo. Or another graphics card if you guys have more tips :)
    I like the PSU you suggested. Good price for a modular and 80+ gold PSU.
    Mindfactory ships to Belgium (according to the very fast response from the sales team there). Does anyone have experience with this store?
  2. *Bump*
New Build Systems
