Yes No
Ads
Tom's Hardware > Forum > Networking > LAN/WAN > Ethernet port / network card not working
Forum Networking : LAN/WAN Ethernet port / network card not working
Hello,
My laptop stopped working for internet. Upon investigation, I found that ethernet port light was not blinking and network cable disconnected error was showing up in system tray. I could not find the network adpter in Device Manager also.
My wireless adapter is working though thankfully :)
Any help will be appreciated.
Thanks,
PK
Reply to padmanabhk
What type of computer is it? IF it is a desktop, is the Ethernet built onto the motherboard, or is it a card?
Reply to PhilFrisbie
Have you made any changes in your BIOS? There may be a setting to disable the network adapter.
If not, then the network adapter has probably died, and you will need to use a USB network adapter.
I agree to Phil, your onboard NIC may have died.
There are some ways to check. First, take your laptop elsewhere to try it and see whether the lights are on or not.
If the lights are back, means the card is working, but not the supply. Do try out the ethernet cable as well.
Do not adjust the advance setting on the properties, like WOL, speed, and stuffs, just set them to auto negotiate and let them run as per normal if you did anything to those settings previously.
Get an update on your network adapter and see if it can be installed or not.
Run the add hardware on the control panel and see if it detects the NIC or not.
Or else, RIP to your network adapter and many of us will suggest you get a USB network adapter. It's rather cheap.
Message edited by jesperloh on 01-27-2012 at 03:51:01 AM
Reply to jesperloh
Hi JasperLoh and Phil,
First of all, thank you very much for all your help. I tried everything you mentioned but could not get the LAN can working. So as a last Option as you guys suggested, bought a new USB network adapter and it just worked fine.
I am back online with my wired connect :)
Reply to padmanabhk
There are 1550 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
My desktops internet. HELP
By Realbeast, 1 day ago:
Sure could be a virus or malware, you should use a good free antivirus and...
Best offers
Top experts
